What Grafana version (v8.4.5) and what operating system (linux/kubernetes) are you using?
I am experimenting with some changes to a dashboard, working on a copy in the JSON view. -
Following an edit, I click the “Save” button and receive an alert telling me someone else has changed the code and it will not save. -
What happened?
Changes would be saved so I could see results -
No -
I have not received any response to this post; I’m wondering if it seems incomplete? This is not regarding a specific situation, but is a regular occurrence while I edit code in the JSON view. It is also intermittent, and sometimes I can save; more often, not. Would someone be able to guide me in some way? I am not understanding how a new configuration can be saved outside of my editing session.
Why are you editing json so often, what are you attempting to do? ![]()
Making incremental changes to configuration of dashboard before capturing it to the “final” desired version. We are maintaining dashboard configurations in our Kubernetes infrastructure-as-code.
