Hi! I have a MySQL sources data configured and working in my Grafana 8.3.3 setup.
This is the original value from phpMyAdmin
in the query i have
SELECT
reading_time AS "time",
value1 AS "Piano Terra",
value2 AS "Piano Primo"
FROM Sensor
WHERE
$__timeFilter(reading_time)
ORDER BY reading_time
and the result timeseries graph (with the table on the bottom) is
i’m asking if there is a way to edit the label of the X-Axis tick? Now are MM/DD HH:MM.
I want to edit for my needs.
Thanks
