Dynamic text plugin - refer to data elements
I’m using the Dynamic Text plugin to build a visualization in Grafana and need to get all the distinct values in the field hostname.
I can get all values with:
{{#each data}} {{hostname}} {{/each}}
Is there a way to get only the distinct values @mikhailvolkov ?
@goncalobsantos Depending on your data source, you can get a distinct hostname.
Transformations will be the next option, I am not sure if it’s possible.
3rd option is the JavaScript custom Handlebar definitely can do that.
Thanks @mikhailvolkov. I am currently exploring the third option, defining a custom Handlebar Helper. I can get a toy helper to work.
With the following in my Javascript:
handlebars.registerHelper("hostname", () =>
  [...new Set([host1, host1, host2])]);
and this in my content:
<div>{{hostname}}</div>
I get host1, host2 in my plugin, as desired. However, I can’t figure out the syntax to apply this same logic to the real case. With:
{{#each data}} {{"hostname.keyword"}} {{/each}}
I get all the hosts (including duplicates) in my plugin. So I am trying to pass this as the argument to my javascript function and was thinking that something like this should work. In my javascript:
handlebars.registerHelper("hostname", (allhosts) =>
  [...new Set(allhosts)]);
And this in my content:
<div>{{#hostname data}} {{"hostname.keyword"}} {{/hostname}}</div>
However, in my plugin this prints:
[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object],[object Object]
I have also tried this in my content without success:
<div>{{hostname ({{#each data}} {{"hostname.keyword"}} {{/each}})}}</div>
Any other ideas?
@goncalobsantos It’s not the way how helpers work. Take a look at the examples in the documentation:
It should be something like that:
handlebars.registerHelper("unique", (context) =>
  return <<unique-values-from-the-context>>
Use:
<div>{{unique data}}</div>
Thank you for all your help @mikhailvolkov. Here’s what worked for me:
In my javascript, I defined this custom helper:
handlebars.registerHelper("unique", (context, key) => {
  return [...new Set(context.map(item => item[key]))];
And in my content:
<div>{{#each (unique data "hostname.keyword")}}{{this}}; {{/each}}</div>
This gives me a list of all the unique values in the hostname.keyword column of my dataframe.
@goncalobsantos Glad it worked!
I added your example in the plugin documentation
