Hello
I would like to suggest a feature for dahsboards that would make comparing differents metrics at the same time simpler.
I want that panels of a dashboards are displayed only when certains conditions are fulfilled such as testing if the server have an exporter and displaying the corresponding panels.
This allows to have a single dashboard for all the servers, to compare the information of different exporters at the same time without switching dashboard for each servers and exporters to establish correlations more easily.
Seconded! This is my singlest biggest reason for considering a home-grown dashboard solution.
Are you saying you would build a single dashboard and then if server A had the metric for CPU then it’d show the graph/panel, if it didn’t have that metric, then it wouldn’t show? If so, I believe you used to be able to do this with the scripted dashboards. I’m not aware of a way to do it now. It would be able to basically add conditionals to panels (if something, else something).
I was not aware of scripted dashboard, it seem not well documented.
It would be well if the conditional option be integrated in the dashboard ui because do JS for a dashboard is not that simple.
