Version 10.4.0 - Debian -
I have a dropdown variable to select for which system to show the data. Its shows all the systems also when it didnt have data in the influxdb for the selected time range. I want the dropdown to update the selection based on the selected time range
- How are you trying to achieve it?
Update the dropdown selection based on the timerange
