8.1.3 -
I select one of the available values in drop down list, this filters out data from DB. Grafana should detect what is the time frame for the data that was not filtered out and switch to it to let me see the data. -
Introduce variable with values that is used to filter SQL query -
What happened?
Current data is hidden, time frame stays the same -
Jumps to or suggest to switch to the time frame where some data is available
Hi @isilo,
Welcome to the
community support forums !!
We are excited that you joined our OSS community. Please read about some of the FAQs in the community ![]()
Can you please provide the steps of reproduction so that the community can also try to reproduce it on a test machine?
Please share a screenshot or a small screencast/gif file so that we can see how you are reproducing it and what you want to achieve.
Thanks.
