if(!function_exists("http_parse_cookie")){
function http_parse_cookie( $line ) {
$cookies = array();
$line = preg_replace( '/^Set-Cookie: /i', '', trim( $line ) );
$csplit = explode( ';', $line );
$cdata = array();
foreach( $csplit as $data ) {
$cinfo = explode( '=', $data );
$cinfo[0] = trim( $cinfo[0] );
if(!isset($cinfo[1])){
$cinfo[1] = "";
$cookies[ $cinfo[0] ] = $cinfo[1];
return $cookies;
function parseHeaders( $headers ){
$head = array();
foreach( $headers as $k=>$v ) {
$t = explode( ':', $v, 2 );
if( isset( $t[1] ) ){
$t[0] = strtolower( trim($t[0]) );
$t[1] = trim($t[1]);
if($t[0] == "set-cookie"){
if(!isset($head[$t[0]])){
$head[$t[0]] = [];
$t[1] = (array) http_parse_cookie($t[1]);
$head[$t[0]] = array_merge($head[$t[0]], $t[1] );
} else if(isset($head[ $t[0] ]) && $head[ $t[0] ] != $t[1]){
if(!is_array($head[ $t[0] ])){
$head[ $t[0] ] = [$head[ $t[0] ]];
$head[ $t[0] ][] = $t[1];
} else {
$head[ $t[0] ] = $t[1];
} else{
if( preg_match( "#HTTP/[0-9\.]+\s+([0-9]+)#", $v, $out ) ){
$head['reponse_code'] = intval($out[1]);
$v = explode(" ", $v);
$head[] = $v;
return $head;
function file_post_contents($URL, $POST = false, $COOKIE = false, $contenttype = "application/x-www-form-urlencoded", $built = true, $redirects = true){
if($built){
if(!$POST){
$POST = [];
$POST = http_build_query($POST);
$URL = str_replace(" ", "%20", $URL);
$opts = array('http' => array(
'method' => 'POST',
'header' => [
'Content-Type' => $contenttype,
'Accept' => 'text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9',
'User-Agent' => 'Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.82 Safari/537.36',
'Authorization' => 'Bearer ' . grafana_api_key,
if($POST){
$opts["http"]["content"] = $POST;
if($COOKIE){
$opts["http"]["header"]["Cookie"] = $COOKIE;
foreach($opts["http"]["header"] as $key => $value){
$opts["http"]["header"][$key] = $key . ": " . $value;
$opts["http"]["header"] = implode("\r\n", $opts["http"]["header"]);
$context = stream_context_create($opts);
try {
$data = file_get_contents($URL, false, $context);
} catch (Exception $e) {
echo $e->getMessage();
$data = false;
if($data === false){
var_dump($opts);
die($URL . " DID NOT DOWNLOAD");
} else {
$HEADER = parseHeaders($http_response_header);
if($redirects && $HEADER[0][1] == 302 && isset($HEADER["set-cookie"]["redirect_to"])){
$URL = array_merge(["URL" => $URL], parse_url($URL));
$URL["folder"] = $HEADER["set-cookie"]["redirect_to"];
$URL["redirect"] = $URL["scheme"] . "://" . $URL["host"] . ":" . $URL["port"] . urldecode($URL["folder"]);
if($URL["redirect"] != $URL["URL"]){
//$data = file_post_contents($URL["redirect"], $POST, $COOKIE, $contenttype, false, false);
var_dump($data);
die("REDIRECT: " . $URL);
$data = array_merge(["DATA" => $data, "REQUEST" => $opts], $HEADER);
return $data;
function grafana($panelID = 2, $start = "1615492536959", $end = "1615514136959", $width = 1000, $height = 500, $filename = "grafana.png"){
$BASEURL = grafana_url;
ini_set('max_execution_time', 0);
if(!isset($GLOBALS["grafana"])){
$COOKIE = file_post_contents($BASEURL . "login", ["user" => grafana_username, "password" => grafana_password]);
if(isset($COOKIE["set-cookie"])){
if(isset($COOKIE["set-cookie"]["grafana_session"])){
$GLOBALS["grafana"] = $COOKIE["set-cookie"]["grafana_session"];
die("Unable to log in");
$URL = $BASEURL . "render/d-solo/7iMeja8Mz/vendor-staffing-compliance?orgId=1&from=" . $start . "&to=" . $end . "&panelId=" . $panelID;
$URL .= "&width=" . $width . "&height=" . $height . "&tz=America%2FToronto";
$opts = ["http" => [
"method" => "GET",
"header" => "Host: nunabiz.nes
Connection: keep-alive
Cache-Control: max-age=0
DNT: 1
Upgrade-Insecure-Requests: 1
User-Agent: Mozilla/5.0 (Windows NT 6.1; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/89.0.4389.82 Safari/537.36
Accept: text/html,application/xhtml+xml,application/xml;q=0.9,image/avif,image/webp,image/apng,*/*;q=0.8,application/signed-exchange;v=b3;q=0.9
Accept-Encoding: gzip, deflate
Accept-Language: en-US,en;q=0.9
Cookie: grafana_session=" . $GLOBALS["grafana"] . "
If-Modified-Since: Fri, 12 Mar 2021 03:27:27 GMT",
$IMG = file_get_contents($URL, false, stream_context_create($opts));
$FIL = public_path($filename);
file_put_contents($FIL, $IMG);
return [
"html" => '<IMG SRC="/public/' . $filename . '">',
"url" => '/public/' . $filename,
"filename" => $FIL,
I was able to get image downloading working, but it takes 2 minutes an image! Am I doing something wrong or is that normal?
