Downloading grafanacloud-install.sh (hosted by Google) gives a 403
Set up monitoring of a Linux machine, following the guide at https://[myorg].grafana.net/a/grafana-selfservetutorials-app/linux-node
Simply following the steps in the guide.
  • What happened?
In step 2.2, “Download the Grafana Agent Binary by running the following command”, there’s a command that will download a script from https://storage.googleapis.com/cloud-onboarding/agent/scripts/grafanacloud-install.sh. But this resource returns a 403 status code.
I expect to be able to download the script.
I didn’t configure anything yet.
No.
As already mentioned, I’m following the tutorial at https://[myorg].grafana.net/a/grafana-selfservetutorials-app/linux-node
I believe the latest version of script hosted at grafana agent’s github is this one
Might also want to look at
agent is being depracated
Maybe now would be a good time to remove/replace that built in tutorial then :slight_smile:
Thanks, both of you!
