Unfortunately, with satellite it is not possible to only download alloy from the site: https://rpm.grafana.com. The entire repo is larger than 200G and this is somewhat overkill for just alloy rpm. Is it possible, for example, to download only alloy*.rpm with wget?
Did you try github artifacts?
Is GitHub the source for Grafana?
I don’t understand the question.
