Ask questions and give feedback on Grafana Alloy—
Grafana Alloy is Grafana Labs’ distribution of the OpenTelemetry Collector. It is an OTLP-compatible collector with built-in Prometheus optimizations that also supports signals across metrics, logs, traces, and profiles.
Check out the Grafana Alloy documentation for more information.
Is grafana alloy compatible with Grafana opensource , I am unable to send the metrics from other clusters via grafana alloy using grafana opensource tool. It works fine with grafana cloud but not with grafana opensource.
Grafana Alloy can send your data to whatever destination you define. If you can’t send data to a local Grafana stack I’d guess that there’s something not quite right in your config or in the path between Alloy and the local Grafana stack. This tutorial for example: Use Grafana Alloy to send metrics to Prometheus | Grafana Alloy documentation show you how to send metrics to a local Grafana stack.
GitHub - grafana/k8s-monitoring-helm I used this helm chart for grafana alloy. I have defined in values.yaml
Can someone confirm if the above helm works for Grafana oss
