Grafana cloud (latest I think?) Installing Alloy on Asahi Linux -
I’m trying to install Alloy to complete the installation of the OTLP connector -
via the grafana cloud dashboard walkthrough -
What happened?
The initial installation script worked and the connection test was green. When I added the provided block of config for the open telemetry (“Append this to your config”) I get the following errors when trying to restart Alloy:
Error: ./config.alloy:118:14: component "otelcol.exporter.prometheus.grafana_cloud_prometheus.input" does not exist or is out of scope
117 | output {
118 | metrics = [otelcol.exporter.prometheus.grafana_cloud_prometheus.input]
119 | logs = [otelcol.exporter.loki.grafana_cloud_loki.input]
Error: ./config.alloy:130:25: component "prometheus.remote_write.grafana_cloud_prometheus.receiver" does not exist or is out of scope
129 | add_metric_suffixes = false
130 | forward_to = [prometheus.remote_write.grafana_cloud_prometheus.receiver]
131 | }
interrupt received
Error: could not perform the initial load successfully
Alloy starts successfully and the config given in the dashboard does not have errors. -
Some of it, but it is quite long and has secrets in it. -
No -
I’m following the instructions at <my Grafana cloud url>connections/add-new-connection/open-telemetry
Thanks in advance ![]()
