Does Infinity plugin support querying Prometheus metrics
Does infinity plugin support Prometheus metrics natively.
Thanks,
Ameya
yes if prometheus has a rest api endpoint from which you can return data, if not most probably you cannot
Prometheus does have an API but why would you like to do that? It seems like querying Prometheus by datasource but with many extra steps.
