Does grafana support connection with onetick data source?
I am already using Grafana to create some dashboards and those dashboards are built mainly using elasticsearch data sources.
I have some data stored in onetick data source as well.
Now I want to create some other dashboard using the data which is stored in onetick data source.
I tried to connect to onetick data source from grafana but I did not find a similar datasource support in grafana data source configuration.
Does grafana support onetick data source?
How can I connect to onetick data source from grafana to create dashboards?
Is there any way using which I can call a rest API or something to fetch data from my data source?
