I am using grafana version 8.2.1
I am trying to connect to or update a datasource on dashboard load
Explanation: Say, I have created a grafana dashboard using a datasource X which is postgres. Now I have many databases in postgres. Say my postgresDB have 3 databases, X1, X2, X3.
I have created one dashboard and one datasource and connected the datasource to the dashboard. Now I will pass some informations while the dashboard loads and then with that information, the datasource connection should be changed from X1 or X2 or X3 ( database name,username and pasword should be updated for that datasource). Once the correct database is connected, then grafana should execute the dashboard query from that particular database and fetch data
Is this procedure achievable in any possible ways? Suggestion are welcome.
THANKS.
