Grafana v12.1.0 -
Enabling feature Add state history backend to write ALERTS metric. -
Configuring as documented stated -
What happened?
Was able to see alert state history metrics get remote written to my Prometheus stack.
Though noticed that alert state history is not tracked anymore on the grafana end.
Before when not enabled, was able to see via grafana UI, alert state history. -
Expected to get metrics and as well be able to see state history in grafana end.Just wanted to know if enabling, unified_alerting.state_history
with a prometheus backend.
If you then lose the tracking and showing in grafana , via the alert info view.
