Docker - visualization problem after first build container
Grafan vers.: v11.0.0
no data is displayed on the dashboard
I tried to build a grafana with docker where I included a preconfigured dashboard.
The data source is a .csv file and I am using the marcusolsson-csv-datasource plugin.
When I builded the dashboard json file, the data was there, and the visualization was ok.
After I built the container (docker-compose up --build -d), the dashboard was there, but the panel says No Data.
GitHub link: GitHub - bolcsa/SopronUNI_WebVis: Web visualization with Grafana and Docker
Thx
Andy
Problem resolved.
I added fix uid to the datasource/datasource.yml file
