Docker tags for grafana / grafana-oss
Hiya,
The latest docker tags for grafana-oss (and grafana) seem to be getting confused.
Running docker pull grafana/grafana-oss:latest pulls down an image that is 23 months old (and when it is run gives a version number 10.1.1). Comparing the digests of grafana/grafana-oss:latest and grafana/grafana-oss:10.1.1 shows that they are the same.
I would strongly encourage you to use grafana/grafana and not grafana/grafana-oss, as it will be deprecated soon. It’s pretty much the exact same as grafana/grafana.
Honestly, no clue why grafana/grafana-oss:latest pointed to 10.1.1; it’s updated now.
I’ve switched to using the grafana/grafana tag (although I also verified that grafana-oss:latest had been fixed - thanks!)
I would note that the docker instructions ( Run Grafana Docker image | Grafana documentation ) refer to grafana/grafana-oss or grafana/grafana-enterprise (and not just grafana/grafana).
Thank you for pointing that out, we will update the documentation.
