Hello all,
for the past weeks I’ve been an issue with Grafana Alloy.
I’m running it into a few machines as part of my home lab setup, where I want to collect the logs of some docker containers. I’ve noticed that, after a few days, my Grafana Cloud instance starts to receive a high volume of logs marked as being too old and as a result being discarded.
This in turns contribute to the total log ingestion which starts to grow completely out of control.
It appears as if Alloy tries to send old logs multiple times, because otherwise these docker containers would not produce such high volume of logs.
What seems to bring the situation under control is to stop the containers for a few minutes and restart them. This bring the crazy log ingestion down for a few days until is slowly starts growing again.
Before using Alloy I was using the Grafana Agent and did not have such issue. As the Agent will reach end of life at some point, I thought to start migrating to Alloy sooner.
I’ve checked the GitHub issue tracker and the forum but couldn’t really find something similar to this situation, any idea what might be happening?
Here is my Alloy configuration
// Prometheus
prometheus.exporter.self "integrations_alloy" { }
discovery.relabel "integrations_alloy" {
targets = prometheus.exporter.self.integrations_alloy.targets
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "alloy_hostname"
rule {
target_label = "job"
replacement = "integrations/alloy-check"
prometheus.scrape "integrations_alloy" {
targets = discovery.relabel.integrations_alloy.output
forward_to = [prometheus.relabel.integrations_alloy.receiver]
scrape_interval = "60s"
prometheus.relabel "integrations_alloy" {
rule {
source_labels = ["__name__"]
regex = "(prometheus_target_sync_length_seconds_sum|prometheus_target_scrapes_.*|prometheus_target_interval.*|prometheus_sd_discovered_targets|alloy_build.*|prometheus_remote_write_wal_samples_appended_total|process_start_time_seconds)"
action = "keep"
prometheus.remote_write "metrics_service" {
endpoint {
url = "{{ prometheus_url }}"
basic_auth {
username = "{{ prometheus_username }}"
password = "{{ prometheus_api_key }}"
loki.write "grafana_cloud_loki" {
endpoint {
url = "{{ loki_url }}"
basic_auth {
username = "{{ loki_username }}"
password = "{{ loki_api_key }}"
discovery.relabel "integrations_node_exporter" {
targets = prometheus.exporter.unix.integrations_node_exporter.targets
rule {
rule {
replacement = "integrations/node_exporter"
prometheus.exporter.unix "integrations_node_exporter" {
disable_collectors = ["ipvs", "btrfs", "infiniband", "xfs", "zfs"]
filesystem {
fs_types_exclude = "^(autofs|binfmt_misc|bpf|cgroup2?|configfs|debugfs|devpts|devtmpfs|tmpfs|fusectl|hugetlbfs|iso9660|mqueue|nsfs|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|selinuxfs|squashfs|sysfs|tracefs)$"
mount_points_exclude = "^/(dev|proc|run/credentials/.+|sys|var/lib/docker/.+)($|/)"
mount_timeout = "5s"
netclass {
ignored_devices = "^(veth.*|cali.*|[a-f0-9]{15})$"
netdev {
device_exclude = "^(veth.*|cali.*|[a-f0-9]{15})$"
prometheus.scrape "integrations_node_exporter" {
targets = discovery.relabel.integrations_node_exporter.output
forward_to = [prometheus.relabel.integrations_node_exporter.receiver]
prometheus.relabel "integrations_node_exporter" {
rule {
regex = "up|node_arp_entries|node_boot_time_seconds|node_context_switches_total|node_cpu_seconds_total|node_disk_io_time_seconds_total|node_disk_io_time_weighted_seconds_total|node_disk_read_bytes_total|node_disk_read_time_seconds_total|node_disk_reads_completed_total|node_disk_write_time_seconds_total|node_disk_writes_completed_total|node_disk_written_bytes_total|node_filefd_allocated|node_filefd_maximum|node_filesystem_avail_bytes|node_filesystem_device_error|node_filesystem_files|node_filesystem_files_free|node_filesystem_readonly|node_filesystem_size_bytes|node_intr_total|node_load1|node_load15|node_load5|node_md_disks|node_md_disks_required|node_memory_Active_anon_bytes|node_memory_Active_bytes|node_memory_Active_file_bytes|node_memory_AnonHugePages_bytes|node_memory_AnonPages_bytes|node_memory_Bounce_bytes|node_memory_Buffers_bytes|node_memory_Cached_bytes|node_memory_CommitLimit_bytes|node_memory_Committed_AS_bytes|node_memory_DirectMap1G_bytes|node_memory_DirectMap2M_bytes|node_memory_DirectMap4k_bytes|node_memory_Dirty_bytes|node_memory_HugePages_Free|node_memory_HugePages_Rsvd|node_memory_HugePages_Surp|node_memory_HugePages_Total|node_memory_Hugepagesize_bytes|node_memory_Inactive_anon_bytes|node_memory_Inactive_bytes|node_memory_Inactive_file_bytes|node_memory_Mapped_bytes|node_memory_MemAvailable_bytes|node_memory_MemFree_bytes|node_memory_MemTotal_bytes|node_memory_SReclaimable_bytes|node_memory_SUnreclaim_bytes|node_memory_ShmemHugePages_bytes|node_memory_ShmemPmdMapped_bytes|node_memory_Shmem_bytes|node_memory_Slab_bytes|node_memory_SwapTotal_bytes|node_memory_VmallocChunk_bytes|node_memory_VmallocTotal_bytes|node_memory_VmallocUsed_bytes|node_memory_WritebackTmp_bytes|node_memory_Writeback_bytes|node_netstat_Icmp6_InErrors|node_netstat_Icmp6_InMsgs|node_netstat_Icmp6_OutMsgs|node_netstat_Icmp_InErrors|node_netstat_Icmp_InMsgs|node_netstat_Icmp_OutMsgs|node_netstat_IpExt_InOctets|node_netstat_IpExt_OutOctets|node_netstat_TcpExt_ListenDrops|node_netstat_TcpExt_ListenOverflows|node_netstat_TcpExt_TCPSynRetrans|node_netstat_Tcp_InErrs|node_netstat_Tcp_InSegs|node_netstat_Tcp_OutRsts|node_netstat_Tcp_OutSegs|node_netstat_Tcp_RetransSegs|node_netstat_Udp6_InDatagrams|node_netstat_Udp6_InErrors|node_netstat_Udp6_NoPorts|node_netstat_Udp6_OutDatagrams|node_netstat_Udp6_RcvbufErrors|node_netstat_Udp6_SndbufErrors|node_netstat_UdpLite_InErrors|node_netstat_Udp_InDatagrams|node_netstat_Udp_InErrors|node_netstat_Udp_NoPorts|node_netstat_Udp_OutDatagrams|node_netstat_Udp_RcvbufErrors|node_netstat_Udp_SndbufErrors|node_network_carrier|node_network_info|node_network_mtu_bytes|node_network_receive_bytes_total|node_network_receive_compressed_total|node_network_receive_drop_total|node_network_receive_errs_total|node_network_receive_fifo_total|node_network_receive_multicast_total|node_network_receive_packets_total|node_network_speed_bytes|node_network_transmit_bytes_total|node_network_transmit_compressed_total|node_network_transmit_drop_total|node_network_transmit_errs_total|node_network_transmit_fifo_total|node_network_transmit_multicast_total|node_network_transmit_packets_total|node_network_transmit_queue_length|node_network_up|node_nf_conntrack_entries|node_nf_conntrack_entries_limit|node_os_info|node_sockstat_FRAG6_inuse|node_sockstat_FRAG_inuse|node_sockstat_RAW6_inuse|node_sockstat_RAW_inuse|node_sockstat_TCP6_inuse|node_sockstat_TCP_alloc|node_sockstat_TCP_inuse|node_sockstat_TCP_mem|node_sockstat_TCP_mem_bytes|node_sockstat_TCP_orphan|node_sockstat_TCP_tw|node_sockstat_UDP6_inuse|node_sockstat_UDPLITE6_inuse|node_sockstat_UDPLITE_inuse|node_sockstat_UDP_inuse|node_sockstat_UDP_mem|node_sockstat_UDP_mem_bytes|node_sockstat_sockets_used|node_softnet_dropped_total|node_softnet_processed_total|node_softnet_times_squeezed_total|node_systemd_unit_state|node_textfile_scrape_error|node_time_zone_offset_seconds|node_timex_estimated_error_seconds|node_timex_maxerror_seconds|node_timex_offset_seconds|node_timex_sync_status|node_uname_info|node_vmstat_oom_kill|node_vmstat_pgfault|node_vmstat_pgmajfault|node_vmstat_pgpgin|node_vmstat_pgpgout|node_vmstat_pswpin|node_vmstat_pswpout|process_max_fds|process_open_fds"
action = "keep"
// Loki
loki.source.journal "logs_integrations_integrations_node_exporter_journal_scrape" {
max_age = "24h0m0s"
relabel_rules = discovery.relabel.logs_integrations_integrations_node_exporter_journal_scrape.rules
forward_to = [loki.write.grafana_cloud_loki.receiver]
local.file_match "logs_integrations_integrations_node_exporter_direct_scrape" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/{syslog,messages,*.log}",
instance = constants.hostname,
job = "integrations/node_exporter",
discovery.relabel "logs_integrations_integrations_node_exporter_journal_scrape" {
targets = []
rule {
source_labels = ["__journal__systemd_unit"]
target_label = "unit"
rule {
source_labels = ["__journal__boot_id"]
target_label = "boot_id"
rule {
source_labels = ["__journal__transport"]
target_label = "transport"
rule {
source_labels = ["__journal_priority_keyword"]
target_label = "level"
rule {
source_labels = ["__journal_syslog_identifier"]
target_label = "syslog_identifier"
rule {
loki.source.file "logs_integrations_integrations_node_exporter_direct_scrape" {
targets = local.file_match.logs_integrations_integrations_node_exporter_direct_scrape.targets
// Docker
prometheus.exporter.cadvisor "integrations_cadvisor" {
docker_only = true
discovery.relabel "integrations_cadvisor" {
targets = prometheus.exporter.cadvisor.integrations_cadvisor.targets
rule {
replacement = "integrations/docker"
rule {
prometheus.relabel "integrations_cadvisor" {
rule {
regex = "up|container_cpu_usage_seconds_total|container_fs_inodes_free|container_fs_inodes_total|container_fs_limit_bytes|container_fs_usage_bytes|container_last_seen|container_memory_usage_bytes|container_network_receive_bytes_total|container_network_tcp_usage_total|container_network_transmit_bytes_total|container_spec_memory_reservation_limit_bytes|machine_memory_bytes|machine_scrape_error"
action = "keep"
prometheus.scrape "integrations_cadvisor" {
targets = discovery.relabel.integrations_cadvisor.output
forward_to = [prometheus.relabel.integrations_cadvisor.receiver]
discovery.docker "logs_integrations_docker" {
host = "unix:///var/run/docker.sock"
refresh_interval = "5s"
discovery.relabel "logs_integrations_docker" {
targets = []
rule {
rule {
rule {
source_labels = ["__meta_docker_container_name"]
regex = "/(.*)"
target_label = "container"
rule {
source_labels = ["__meta_docker_container_log_stream"]
target_label = "stream"
loki.source.docker "logs_integrations_docker" {
targets = discovery.docker.logs_integrations_docker.targets
relabel_rules = discovery.relabel.logs_integrations_docker.rules
I don’t have the full Agent configuration, but here is the snippet I was using to collect docker logs
Grafana Agent docker logs
- docker_sd_configs:
- host: unix:///var/run/docker.sock
refresh_interval: 5s
job_name: integrations/docker
relabel_configs:
- replacement: yavin4
target_label: instance
- replacement: integrations/docker
target_label: integration
- source_labels:
- __meta_docker_container_id
target_label: containerid
- regex: /(.*)
source_labels:
- __meta_docker_container_name
- source_labels:
- __meta_docker_container_log_stream
target_label: stream
- source_labels:
- __meta_docker_container_label_appname
target_label: appname
- source_labels:
- __meta_docker_container_label_env
target_label: env
- source_labels:
- __meta_docker_container_label_custom
target_label: custom
target_config:
sync_period: 10s
