Docker logs have timestamp too old
Cool. Here is what I suspect is happening.
I suspect Alloy is not accurately keeping position for some reason for containers that are on a network. This results in logs being continuously processed and forwarded regardless of age because no position is kept. This also explains why adding a drop stage works.
I’ll still try to put together some sort of test case, and this probably should be submitted as bugs as well. But for now at least we have a workaround.
Oh, if you are using Grafana Cloud you may also consider reaching out to support directly. They may already have similar report, and if you are being charged for the discarded logs I hope they can do something about that.
Thanks @tonyswumac I’ll submit this to support and let’s see what they say.
Right now I’m on the free plan as I’m using this for my personal homelab, so I’m not been charged, but the discarded logs do account for the total 50GB you have on the free plan, so it has been quite difficult for the past two month keeping it in check :sweat_smile:
Hey @tonyswumac I wanted to provide a quick update on this issue.
I’ve contacted support and we’ve been trying to have them replicate the same behavior I’m experiencing but so far no luck.
I don’t understand how this is possible as it seems I am capable of replicating it, I’ve even setup new VMs and the issue seems to appear pretty consistently with my setup.
I’ll leave below the instruction to replicate it just in case you might still wanna give this a go.
Operating system: openSUSE Tumbleweed.
Alloy version: v1.1.1 (branch: HEAD, revision: 2687a2d85)
Alloy configuration file:
config.alloy
          // Prometheus
          prometheus.exporter.self "integrations_alloy" { }
          discovery.relabel "integrations_alloy" {
            targets = prometheus.exporter.self.integrations_alloy.targets
            rule {
              target_label = "instance"
            rule {
              target_label = "alloy_hostname"
            rule {
              target_label = "job"
              replacement  = "integrations/alloy-check"
          prometheus.scrape "integrations_alloy" {
            targets    = discovery.relabel.integrations_alloy.output
            forward_to = [prometheus.relabel.integrations_alloy.receiver]
            scrape_interval = "60s"
          prometheus.relabel "integrations_alloy" {
            rule {
              source_labels = ["__name__"]
              regex         = "(prometheus_target_sync_length_seconds_sum|prometheus_target_scrapes_.*|prometheus_target_interval.*|prometheus_sd_discovered_targets|alloy_build.*|prometheus_remote_write_wal_samples_appended_total|process_start_time_seconds)"
              action        = "keep"
          prometheus.remote_write "metrics_service" {
            endpoint {
              url = "{{ prometheus_url }}"
              basic_auth {
                username = "{{ prometheus_username }}"
                password = "{{ prometheus_api_key }}"
          loki.write "grafana_cloud_loki" {
            endpoint {
              url = "{{ loki_url }}"
              basic_auth {
                username = "{{ loki_username }}"
                password = "{{ loki_api_key }}"
          discovery.relabel "integrations_node_exporter" {
            targets = prometheus.exporter.unix.integrations_node_exporter.targets
            rule {
            rule {
              replacement = "integrations/node_exporter"
          prometheus.exporter.unix "integrations_node_exporter" {
            disable_collectors = ["ipvs", "btrfs", "infiniband", "xfs", "zfs"]
            filesystem {
              fs_types_exclude     = "^(autofs|binfmt_misc|bpf|cgroup2?|configfs|debugfs|devpts|devtmpfs|tmpfs|fusectl|hugetlbfs|iso9660|mqueue|nsfs|overlay|proc|procfs|pstore|rpc_pipefs|securityfs|selinuxfs|squashfs|sysfs|tracefs)$"
              mount_points_exclude = "^/(dev|proc|run/credentials/.+|sys|var/lib/docker/.+)($|/)"
              mount_timeout        = "5s"
            netclass {
              ignored_devices = "^(veth.*|cali.*|[a-f0-9]{15})$"
            netdev {
              device_exclude = "^(veth.*|cali.*|[a-f0-9]{15})$"
          prometheus.scrape "integrations_node_exporter" {
            targets    = discovery.relabel.integrations_node_exporter.output
            forward_to = [prometheus.relabel.integrations_node_exporter.receiver]
          prometheus.relabel "integrations_node_exporter" {
            rule {
              regex         = "up|node_arp_entries|node_boot_time_seconds|node_context_switches_total|node_cpu_seconds_total|node_disk_io_time_seconds_total|node_disk_io_time_weighted_seconds_total|node_disk_read_bytes_total|node_disk_read_time_seconds_total|node_disk_reads_completed_total|node_disk_write_time_seconds_total|node_disk_writes_completed_total|node_disk_written_bytes_total|node_filefd_allocated|node_filefd_maximum|node_filesystem_avail_bytes|node_filesystem_device_error|node_filesystem_files|node_filesystem_files_free|node_filesystem_readonly|node_filesystem_size_bytes|node_intr_total|node_load1|node_load15|node_load5|node_md_disks|node_md_disks_required|node_memory_Active_anon_bytes|node_memory_Active_bytes|node_memory_Active_file_bytes|node_memory_AnonHugePages_bytes|node_memory_AnonPages_bytes|node_memory_Bounce_bytes|node_memory_Buffers_bytes|node_memory_Cached_bytes|node_memory_CommitLimit_bytes|node_memory_Committed_AS_bytes|node_memory_DirectMap1G_bytes|node_memory_DirectMap2M_bytes|node_memory_DirectMap4k_bytes|node_memory_Dirty_bytes|node_memory_HugePages_Free|node_memory_HugePages_Rsvd|node_memory_HugePages_Surp|node_memory_HugePages_Total|node_memory_Hugepagesize_bytes|node_memory_Inactive_anon_bytes|node_memory_Inactive_bytes|node_memory_Inactive_file_bytes|node_memory_Mapped_bytes|node_memory_MemAvailable_bytes|node_memory_MemFree_bytes|node_memory_MemTotal_bytes|node_memory_SReclaimable_bytes|node_memory_SUnreclaim_bytes|node_memory_ShmemHugePages_bytes|node_memory_ShmemPmdMapped_bytes|node_memory_Shmem_bytes|node_memory_Slab_bytes|node_memory_SwapTotal_bytes|node_memory_VmallocChunk_bytes|node_memory_VmallocTotal_bytes|node_memory_VmallocUsed_bytes|node_memory_WritebackTmp_bytes|node_memory_Writeback_bytes|node_netstat_Icmp6_InErrors|node_netstat_Icmp6_InMsgs|node_netstat_Icmp6_OutMsgs|node_netstat_Icmp_InErrors|node_netstat_Icmp_InMsgs|node_netstat_Icmp_OutMsgs|node_netstat_IpExt_InOctets|node_netstat_IpExt_OutOctets|node_netstat_TcpExt_ListenDrops|node_netstat_TcpExt_ListenOverflows|node_netstat_TcpExt_TCPSynRetrans|node_netstat_Tcp_InErrs|node_netstat_Tcp_InSegs|node_netstat_Tcp_OutRsts|node_netstat_Tcp_OutSegs|node_netstat_Tcp_RetransSegs|node_netstat_Udp6_InDatagrams|node_netstat_Udp6_InErrors|node_netstat_Udp6_NoPorts|node_netstat_Udp6_OutDatagrams|node_netstat_Udp6_RcvbufErrors|node_netstat_Udp6_SndbufErrors|node_netstat_UdpLite_InErrors|node_netstat_Udp_InDatagrams|node_netstat_Udp_InErrors|node_netstat_Udp_NoPorts|node_netstat_Udp_OutDatagrams|node_netstat_Udp_RcvbufErrors|node_netstat_Udp_SndbufErrors|node_network_carrier|node_network_info|node_network_mtu_bytes|node_network_receive_bytes_total|node_network_receive_compressed_total|node_network_receive_drop_total|node_network_receive_errs_total|node_network_receive_fifo_total|node_network_receive_multicast_total|node_network_receive_packets_total|node_network_speed_bytes|node_network_transmit_bytes_total|node_network_transmit_compressed_total|node_network_transmit_drop_total|node_network_transmit_errs_total|node_network_transmit_fifo_total|node_network_transmit_multicast_total|node_network_transmit_packets_total|node_network_transmit_queue_length|node_network_up|node_nf_conntrack_entries|node_nf_conntrack_entries_limit|node_os_info|node_sockstat_FRAG6_inuse|node_sockstat_FRAG_inuse|node_sockstat_RAW6_inuse|node_sockstat_RAW_inuse|node_sockstat_TCP6_inuse|node_sockstat_TCP_alloc|node_sockstat_TCP_inuse|node_sockstat_TCP_mem|node_sockstat_TCP_mem_bytes|node_sockstat_TCP_orphan|node_sockstat_TCP_tw|node_sockstat_UDP6_inuse|node_sockstat_UDPLITE6_inuse|node_sockstat_UDPLITE_inuse|node_sockstat_UDP_inuse|node_sockstat_UDP_mem|node_sockstat_UDP_mem_bytes|node_sockstat_sockets_used|node_softnet_dropped_total|node_softnet_processed_total|node_softnet_times_squeezed_total|node_systemd_unit_state|node_textfile_scrape_error|node_time_zone_offset_seconds|node_timex_estimated_error_seconds|node_timex_maxerror_seconds|node_timex_offset_seconds|node_timex_sync_status|node_uname_info|node_vmstat_oom_kill|node_vmstat_pgfault|node_vmstat_pgmajfault|node_vmstat_pgpgin|node_vmstat_pgpgout|node_vmstat_pswpin|node_vmstat_pswpout|process_max_fds|process_open_fds"
              action        = "keep"
          // Loki
          loki.source.journal "logs_integrations_integrations_node_exporter_journal_scrape" {
            max_age       = "24h0m0s"
            relabel_rules = discovery.relabel.logs_integrations_integrations_node_exporter_journal_scrape.rules
            forward_to    = [loki.write.grafana_cloud_loki.receiver]
          local.file_match "logs_integrations_integrations_node_exporter_direct_scrape" {
            path_targets = [{
              __address__ = "localhost",
              __path__    = "/var/log/{syslog,messages,*.log}",
              instance    = constants.hostname,
              job         = "integrations/node_exporter",
          discovery.relabel "logs_integrations_integrations_node_exporter_journal_scrape" {
            targets = []
            rule {
              source_labels = ["__journal__systemd_unit"]
              target_label  = "unit"
            rule {
              source_labels = ["__journal__boot_id"]
              target_label  = "boot_id"
            rule {
              source_labels = ["__journal__transport"]
              target_label  = "transport"
            rule {
              source_labels = ["__journal_priority_keyword"]
              target_label  = "level"
            rule {
              source_labels = ["__journal_syslog_identifier"]
              target_label  = "syslog_identifier"
            rule {
          loki.source.file "logs_integrations_integrations_node_exporter_direct_scrape" {
            targets    = local.file_match.logs_integrations_integrations_node_exporter_direct_scrape.targets
          // Docker
          prometheus.exporter.cadvisor "integrations_cadvisor" {
            docker_only = true
          discovery.relabel "integrations_cadvisor" {
              targets = prometheus.exporter.cadvisor.integrations_cadvisor.targets
              rule {
                  replacement  = "integrations/docker"
              rule {
          prometheus.relabel "integrations_cadvisor" {
          	rule {
          		regex         = "up|container_cpu_usage_seconds_total|container_fs_inodes_free|container_fs_inodes_total|container_fs_limit_bytes|container_fs_usage_bytes|container_last_seen|container_memory_usage_bytes|container_network_receive_bytes_total|container_network_tcp_usage_total|container_network_transmit_bytes_total|container_spec_memory_reservation_limit_bytes|machine_memory_bytes|machine_scrape_error"
          		action        = "keep"
          prometheus.scrape "integrations_cadvisor" {
              targets    = discovery.relabel.integrations_cadvisor.output
              forward_to = [prometheus.relabel.integrations_cadvisor.receiver]
          discovery.docker "logs_integrations_docker" {
              host             = "unix:///var/run/docker.sock"
              refresh_interval = "5s"
          discovery.relabel "logs_integrations_docker" {
              targets = []
              rule {
              rule {
              rule {
                  source_labels = ["__meta_docker_container_name"]
                  regex         = "/(.*)"
                  target_label  = "container"
              rule {
                  source_labels = ["__meta_docker_container_log_stream"]
                  target_label  = "stream"
          loki.source.docker "logs_integrations_docker" {
             targets          = discovery.docker.logs_integrations_docker.targets
             relabel_rules    = discovery.relabel.logs_integrations_docker.rules
Environment to reproduce the issue:
Start a caddy container in docker with logging enable
docker-compose.yaml
services:
  caddy:
    image: caddy:latest
    restart: unless-stopped
    ports:
      - 443:443
      - 80:80
      - 2018:2018
    volumes:
      - ./Caddyfile:/etc/caddy/Caddyfile
      - ./data:/data
      - ./config:/config
    networks:
      - proxynet
networks:
  proxynet:
    driver: bridge
Caddyfile
:80 {
respond "Welcome to hoth2!"
log {
    format json
Caddyfile
:80 {
respond "Welcome!"
log {
    format json
start an ubuntu container on the same network and run multiple curl caddy in a loop against the caddy container.
sudo docker run -it --network=prx ubuntu bash
One additional thing that I noticed is that the log ingestion volume has to be pretty high. If you look at the screenshot below, before time 21:35 nothing was been discarded, past that time thats when logs started to be discarded. Basically you have to hit caddy very hard to trigger the discard scenario.
do you see the same issue if running a loki instance in same network?
what host are these docker containers running on? straight raw on laptop or some home lab kubernetes or Mikro8s?
What is the date.clock setting on host though Docker containers, by default, use the UTC timezone
are you pushing the container logs to a central storage or is alloy reading it straight from the containers?
I haven’t tried with a Loki instance in the same network as I’m using Grafana Cloud. Also this was not happening with the Grafana agent.
The containers are running straight raw from the laptop and the time is in UTC.
No I’m not pushing the logs to a central unit. Alloy reads them straight from the containers and push them straight to Grafana cloud.
ok so to try things out on our side, I think it would be helpful if you shared a github repo with 2 folders. wether run locally or on cloud things should work the same I would imagine.
folder1 (proves alloy not working)
docker-compose file for
  • loki
  • caddy
  • alloy
    loki config
    caddy config
    alloy config
folder2 (proves agent works)
docker-compose file
  • loki
  • caddy
  • agent
    caddy config
    agent config
    loki config
I believe I have shared all you have requested in my previous post, with the only two exceptions of
  • grafana-agent configuration: because, stupid me, I did not keep it. But honestly when I was using it I did not do any customization. I’ve simply followed step by step the instructions provided from the “add new connection” from Grafana Cloud.
  • Loki configuration: I’m not self hosting Loki, I’m using Grafana Cloud, so I don’t have a configuration for Loki to share.
I’ve asked also a friend of mine to help me replicating the issue on this environment so I’ll try that and keep you posted.
Hi guys,
I realize this is an old thread, but seem to be having the same issue, with the same (old, old) timestamps showing up in multiple of these errors.
Has anyone been able to figure out some new information here?
Thanks :slight_smile:
Hey @bverhoog I haven’t been able to identify the actual reason as to why this happens, but the workaround suggested here seemed to be working for me and I haven’t had the issue ever since. Essentially just use the following directive to drop logs that are too old:
stage.drop {
    source = "timestamp" # or whatever label you parse timestamp into
    older_than = "15m"
    drop_counter_reason = "too old"
