Loki Logs are not Coming after some time in Grafana
failed to call resources
Logs are Coming only some time after Loki alloy setup, Please some one let me know if i have done any wrong configs of if i need to update anything over here .
lokivalues.yaml
test:
  enabled: false
monitoring:
  selfMonitoring:
    enabled: false
    grafanaAgent:
      installOperator: false
read:
  replicas: 3
  nodeSelector:
    Environment:
backend:
  replicas: 3
  persistence:
    storageClass: gp2
  extraVolumes:
    - name: retention
      emptyDir: {}
  extraVolumeMounts:
    - name: retention
      mountPath: /data
  nodeSelector:
    Environment:
write:
  replicas: 3
  persistence:
    storageClass: gp2
  nodeSelector:
    Environment:
loki:
  limits_config:
    max_query_lookback: 25h
    retention_period: 25h
  compactor:
    working_directory: /data/retention
    delete_request_store: s3
    retention_enabled: true
  commonConfig:
    replication_factor: 3
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: index_
          period: 24h
        chunks:
          period: 24h
  storage:
    bucketNames:
      chunks:
      ruler:
      admin:
    type: s3
    s3:
      # endpoint: <MINIO-ENDPOINT>
      region: ap-south-1
      secretAccessKey:
      accessKeyId:
      s3ForcePathStyle: true
      insecure: false
  auth_enabled: false
  nodeSelector:
    Environment:
lokiCanary:
  enabled: false
     helm install loki -n loki grafana/loki -f loki-scalable-values.yml --create-namespace
Alloy Configs
alloy.configmap
apiVersion: v1
kind: ConfigMap
metadata:
  namespace: alloy-logs
data:
  config.alloy: |
     discovery.kubernetes "pods" {
       role = "pod"
     discovery.relabel "pod_logs" {
       targets = discovery.kubernetes.pods.targets
       rule {
         source_labels = ["__meta_kubernetes_namespace"]
         target_label  = "namespace"
       rule {
         source_labels = ["__meta_kubernetes_pod_name"]
         target_label  = "pod"
       rule {
         source_labels = ["__meta_kubernetes_pod_container_name"]
         target_label  = "container"
       rule {
         source_labels = ["__meta_kubernetes_namespace", "__meta_kubernetes_pod_name"]
         separator     = "/"
         target_label  = "job"
       rule {
         source_labels = ["__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name"]
         separator     = "/"
         action        = "replace"
         replacement   = "/var/log/pods/*$1/*.log"
         target_label  = "__path__"
       rule {
         action = "replace"
         source_labels = ["__meta_kubernetes_pod_container_id"]
         regex = "^(\\w+):\\/\\/.+$"
         replacement = "$1"
         target_label = "tmp_container_runtime"
     local.file_match "pod_logs" {
       path_targets = discovery.relabel.pod_logs.output
     loki.source.file "pod_logs" {
       targets    = local.file_match.pod_logs.targets
       forward_to = [loki.process.pod_logs.receiver]
     loki.process "pod_logs" {
       stage.match {
         selector = "{namespace!~\"^(loki|alloy-logs)$\"}"
         stage.regex {
           expression = "(?P<method>GET|PUT|DELETE|POST)"
         stage.regex {
           expression = "(?P<status_code_with_http_version>HTTP.{6}\\d{3})"
         stage.regex {
           expression = "(?P<status_code>\\d{3})"
           source = "status_code_with_http_version"
         stage.labels {
           values = {
             method = "",
             status_code = "",
       stage.match {
         selector = "{tmp_container_runtime=\"containerd\"}"
         stage.cri {}
         stage.labels {
           values = {
             flags   = "",
             stream  = "",
       stage.match {
         selector = "{tmp_container_runtime=\"docker\"}"
         stage.docker {}
         stage.labels {
           values = {
             stream  = "",
       stage.label_drop {
         values = ["tmp_container_runtime"]
       forward_to = [loki.write.loki.receiver]
     loki.write "loki" {
       endpoint {
         url = "http://loki-gateway.loki.svc.cluster.local/loki/api/v1/push"
alloy_values.yaml
alloy:
  configMap:
    create: false
    key: config.alloy
  clustering:
    enabled: false
  mounts:
    varlog: true
controller:
  type: 'daemonset'
First thing you need to figure out is where the problem is. Were you able to determine if the problem is with your Loki cluster or Alloy?
