Log-gaps when high amount of logs
Hi all,
we are running Loki in monolithic mode within our Kubernetes cluster. A Grafana Alloy Daemonset is sending logs from every of the clusters nodes.
One of our components is writing 15k logs per second at peek and somehow there are huge gaps (sometimes more than 30s) in these logs. Having a look at the logs located on the node, there are no gaps, so the components writes all its logs correctly, but they dont arrive at loki and so are not available at Grafana when sending a query for these logs.
Already tried a lot of different configurations, which look like this at the moment:
Loki-configs:
config.yaml: |
    analytics:
      reporting_enabled: false
    auth_enabled: false
    common:
      compactor_address: 'http://loki:3100'
      path_prefix: /var/loki
      replication_factor: 1
      storage:
        filesystem:
          chunks_directory: /var/loki/chunks
          rules_directory: /var/loki/rules
    compactor:
      compaction_interval: 5m
      delete_request_store: filesystem
      retention_delete_delay: 1h
      retention_enabled: true
      working_directory: /var/loki/compactor
    frontend:
      scheduler_address: ""
      tail_proxy_url: "http://loki-querier.{{ .Release.Namespace }}.svc.cluster.local:3100"
    frontend_worker:
    index_gateway:
      mode: ring
    ingester:
      lifecycler:
        heartbeat_timeout: 10m
      chunk_target_size: 1572864
      chunk_idle_period: 5m
      max_chunk_age: 4h
      flush_check_period: 12s
      wal:
        enabled: true
        dir: /var/loki/wal
      flush_op_backoff:
        min_period: 500ms
        max_period: 10s
    ingester_client:
      grpc_client_config:
        max_recv_msg_size: 209715200
        max_send_msg_size: 104857600
      remote_timeout: 60s
    limits_config:
      ingestion_burst_size_mb: 256
      ingestion_rate_mb: 256
      per_stream_rate_limit: 25MB
      per_stream_rate_limit_burst: 50MB
      max_query_lookback: {{ .Values.retentionPeriod }}
      max_query_series: 10000
      max_entries_limit_per_query: 20000
      query_timeout: 300s
      retention_period: {{ .Values.retentionPeriod }}
      max_label_value_length: 40960
      max_line_size: 512KB
      max_line_size_truncate: true
      max_structured_metadata_size: 256KB
      max_streams_per_user: 100000
      max_global_streams_per_user: 200000
    memberlist:
      join_members:
      - loki
    pattern_ingester:
      enabled: false
    ruler:
      storage:
        type: local
    schema_config:
      configs:
        index:
          period: 24h
          prefix: loki_index_
        object_store: filesystem
        schema: v13
        store: tsdb
    server:
      grpc_listen_port: 9995
      http_listen_port: 3100
      http_server_read_timeout: 600s
      http_server_write_timeout: 600s
      grpc_server_max_recv_msg_size: 209715200
      grpc_server_max_send_msg_size: 104857600
    storage_config:
      filesystem:
      hedging:
        at: 250ms
        max_per_second: 20
        up_to: 3
      tsdb_shipper:
        active_index_directory: /var/loki/tsdb-shipper-active
        index_gateway_client:
          server_address: ""
    tracing:
      enabled: false
containers:
        - name: loki
          resources:
            requests:
              cpu: 2
              memory: 1Gi
            limits:
              cpu: 4
              memory: 4Gi
Alloy-configuration regarding logs:
loki.write "lokilogs_integrations" {
      endpoint {
        url = "http://loki.{{ .Release.Namespace }}.svc.cluster.local:3100/loki/api/v1/push"
        batch_wait = "1s"
        batch_size = "8MiB"
        remote_timeout = "60s"
      external_labels = {
        cluster = "{{ .Values.global.clusterurl }}",
        job     = "integrations/logging",
loki.process "logs_integrations_integrations_kubernetes_pod_logs" {
      forward_to = [loki.write.lokilogs_integrations.receiver]
      stage.docker {}
      stage.match {
        selector = "{app=~\".*mfc.*\"}"
        stage.replace {
          expression = "(.+\\s[F,P]\\s)"
          replace    = ""
        stage.multiline {
          firstline     = "^(\\[[^\\]]*\\] ){4}"
          max_lines     = 8000
          max_wait_time = "30s"
        stage.regex {
          expression = "^\\[(?P<time>[^\\]]+)\\] \\[(?P<level>[^ \\]]+) *\\] \\[(?P<threadId>[^ \\]]+) *\\] \\[(?P<logger>[^\\]]+)\\] ( ?\\[(?P<threadExecutionContext>[^\\]]+)\\])? ?(?P<message>.+)"
        stage.timestamp {
          source = "time"
          format = "RFC3339Nano"
        stage.structured_metadata {
          values = {
            level                  = "",
            logger                 = "",
            message                = "",
            threadExecutionContext = "",
            threadId               = "",
    discovery.relabel "logs_integrations_integrations_kubernetes_pod_logs" {
      targets = discovery.kubernetes.k8s_pods.targets
      rule {
        source_labels = ["__address__", "__meta_kubernetes_pod_container_port_number"]
        regex         = "(.+)"
        action        = "replace"
        target_label  = "__address__"
        replacement   = "$1:$2"
      rule {
      source_labels = ["__meta_kubernetes_pod_controller_name"]
      regex         = "([0-9a-z-.]+?)(-[0-9a-f]{8,10})?"
      target_label  = "__tmp_controller_name"
      rule {
      source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_name", "__meta_kubernetes_pod_label_app", "__tmp_controller_name", "__meta_kubernetes_pod_name"]
      regex         = "^;*([^;]+)(;.*)?$"
      target_label  = "app"
      rule {
      source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_instance", "__meta_kubernetes_pod_label_instance"]
      target_label  = "instance"
      rule {
      source_labels = ["__meta_kubernetes_pod_label_app_kubernetes_io_component", "__meta_kubernetes_pod_label_component"]
      target_label  = "component"
      rule {
      source_labels = ["__meta_kubernetes_pod_node_name"]
      target_label  = "node_name"
      rule {
      source_labels = ["__meta_kubernetes_namespace"]
      target_label  = "namespace"
      rule {
      source_labels = ["namespace", "app"]
      separator     = "/"
      target_label  = "service"
      rule {
      source_labels = ["__meta_kubernetes_pod_name"]
      target_label  = "pod"
      rule {
      source_labels = ["__meta_kubernetes_pod_container_name"]
      target_label  = "container"
      rule {
      source_labels = ["__meta_kubernetes_pod_uid", "__meta_kubernetes_pod_container_name"]
      separator     = "/"
      target_label  = "__path__"
      replacement   = "/var/log/pods/*$1/*.log"
      rule {
      source_labels = ["__meta_kubernetes_pod_annotationpresent_kubernetes_io_config_hash", "__meta_kubernetes_pod_annotation_kubernetes_io_config_hash", "__meta_kubernetes_pod_container_name"]
      separator     = "/"
      regex         = "true/(.*)"
Hopefully you guys have some idea which can solve these log gaps.
Kind regards, Christian
Don’t see anything obvious in your config, but since you have WAL turned on, if you are missing logs that means it’s not even able to write to WAL, which is a bad sign. I’d check and see if your disk is perhaps under too much load, make sure your Loki container has sufficient number of file descriptors, and consider collecting metrics from your loki container (/metrics) and see if you can spot the problem there.
I just found out that the formatting of the logs in the alloy-config ist at least one of the main reasons for the gaps in the logs. Removing all this:
        stage.regex {
        stage.timestamp {
          source = "time"
          values = {
            level                  = "",
            logger                 = "",
            message                = "",
            threadId               = "",
made most of the gaps disappear.
Maybe alloy is not able to process this huge amount of logs and format/extract labels/etc out of them? Increasing batch_size didnt solve it - is there another configuration I can make to make alloy able to process all of the logs without “losing” some of them?
I’ve never had problem with alloy not able to process logs. How much resource are you giving it?
More than it needs.
Alloy and Loki are both running at about the half of the limit for cpu and ram usage is set.
