I am using a docker image and I foolishly installed grafana-cli plugins install grafana-image-renderer (from the running container’s bash) before I read that it is not supported by the image. Now even if I remove the image and pull the image from scratch it sees the plugin somewhere and fails to run the container. How do I uninstall this plugin from wherever it lives. Or stop image from picking it up?
How can I remove that plugin, so the image does not try to implement it?
I don’t know… I was in a hurry and saw this Grafana Image Renderer plugin for Grafana | Grafana Labs and I thought I’d just run the installation line and then continue reading… only if I read another line right after that I would have been on the safe side… but I hope there is a solution to my case… I am sure that plugin lives somewhere and can be removed by some machinery
Just for anybody having done the same stupid thing :-S
I run Grafana on unraid in a docker container and also installed the grafana-image-renderer with the grafana-cli.
The grafana container will not start after that anymore so the uninstall process proposed by @furmek will not work.
I removed the grafana-image-renderer folder from /mnt/user/grafana/plugins
After that the container restarts normally.
The plugin cannot be installed in a docker container. Not via the grafana-cli nor via the plugins option in the ui.
You must be running a faster box than I do @ronbbrein for me grafana would start “booting” and die after ~5s. Just enough time to run uninstall command.
As for running renderer in docker - yes you can: Grafana Image Renderer plugin for Grafana | Grafana Labs - Run in Docker section
