Grafana Plugins Installation
Hi
we are using grafana docker image to setup grafana environment on AWS ECS with RDS. When we first setup we went without any plugins. Now we added few plugins and also upgraded the version to 4.3.1. I see the plugins are downloaded and installed into /var/lib/grafana/plugins folder in the docker image. But none of plugins got initialized when image got started and i dont see any of them in the UI.
GF_INSTALL_PLUGINS=“grafana-clock-panel,grafana-worldmap-panel,grafana-simple-json-datasource,alexanderzobnin-zabbix-app,grafana-piechart-panel,grafana-kairosdb-datasource”
Am i missing something?
Found the issue and fixed it. it’s an issue with custom plugin how i am adding to plugins folder in my docker image.
