Hi Grafana Team,
The grafana docker container not able to connect with elasticsearch datasource throwing 502 error on the UI and blow error on the log.The elasticsearch cluster server is running on different host. so I configured the elasticsearch elb address in the grafana datasource.
console log
t=2020-01-09T10:49:27+0000 lvl=info msg=“HTTP Server Listen” logger=http.server address=0.0.0.0:3000 protocol=http subUrl= socket=
2020/01/09 10:52:03 http: proxy error: dial tcp: lookup elasticsearch on xx.xxx.xxx.xxx:xx: no such host
t=2020-01-09T10:52:03+0000 lvl=info msg=“Request Completed” logger=context userId=1 orgId=1 uname=admin method=GET path=/api/datasources/proxy/1/*/_mapping status=502 remote_addr=xx.xxx.xx.xx time_ms=31 size=0 referer=http://internal-xxxxx-xxxx-xxx-tem-gf-xxxxx.eu-xxxx-1.elb.xxxxxx.com/datasources/edit/1/
grafana version: 6.5.2
docker cmd:
docker run
-p 35602:3000
-h grafana
–name grafana
-v grafana-storage:/var/lib/grafana
-u 0
-e “LS_JAVA_OPTS=-Xmx4g -Xms4g”
grafana/grafana:6.5.2
Could someone please help me to resolve this issue.
