Docker-compose loki setup - can't get ruler endpoint
We’re using docker-compose to stand up our Loki stack using Simple Scalable Deployment (not K8s). We currently have our Ruler storage set up to use local filesystem because it just works, however, we’d prefer to use our on-prem s3 storage. I’ve noticed by browsing the community forums here that rules need to be put into s3 via Loki http API, so while exploring the API, we noticed that although we can get some endpoints to work fine, like /loki/api/v1/query_range and /metrics, /ready, /memberlist, /ring, etc… we cannot get /loki/api/v1/rules to list the current rules we have in local storage, nor can we use that endpoint to add rules. Instead, that endpoint returns a 404.
We can switch our Ruler storage to s3, but can’t get rules into it unless we can get the API working.
Below is our docker-compose and loki configs. Any help on getting the endpoint working would be great.
auth_enabled: false
server:
  http_listen_port: 3100
  http_server_read_timeout: 10m
  http_server_write_timeout: 10m
  http_server_idle_timeout: 10m
  grpc_listen_port: 9096
  grpc_server_max_recv_msg_size: 10485760
  grpc_server_max_send_msg_size: 10485760
memberlist:
  join_members: #["read", "write", "backend"]
    - loki:7946
  #bind_addr: ['0.0.0.0']
  bind_port: 7946
  gossip_interval: 2s
limits_config:
  allow_structured_metadata: false
  ingestion_rate_mb: 15
  ingestion_burst_size_mb: 30
  per_stream_rate_limit: 10MB
  per_stream_rate_limit_burst: 20MB
  split_queries_by_interval: 10m
ingester_client:
  remote_timeout: 10s
query_range:
  cache_results: true
  parallelise_shardable_queries: false
schema_config:
  configs:
      store: boltdb-shipper
      object_store: s3
      schema: v11
      index:
        prefix: index_
        period: 24h
      store: tsdb
      object_store: s3
      schema: v13
      index:
        prefix: index_
        period: 24h
common:
  path_prefix: /loki
  replication_factor: 1
  compactor_address: http://backend:3100
  storage:
    s3:
      endpoint: https://xxxx.xx.xx
      insecure: true
      bucketnames: se-loki
      access_key_id: XXXXXXX
      secret_access_key: XXXXX
      region: XXXX
      s3forcepathstyle: true
  ring:
    kvstore:
      store: memberlist
ruler:
  storage:
    #type: s3
    type: local
    s3:
      bucketnames: se-loki-ruler
    local:
      directory: /etc/loki/rules
  evaluation_interval: 1m
  alertmanager_url: http://XXXXX.XXX:9093
  enable_api: true
  ring:
    kvstore:
      store: memberlist
networks:
  loki:
services:
  read:
    image: xx.xx.xx.xx/se-loki-read:3.3.2
    deploy:
      mode: replicated
      replicas: 3
      endpoint_mode: dnsrr
    command: "-config.file=/etc/loki/config.yaml -target=read"
    ports:
      - 3101-3103:3100
      - 7946
      - 9095
    volumes:
      - ./config/config.yaml:/etc/loki/config.yaml
    healthcheck:
      test: [ "CMD-SHELL", "wget --no-verbose --tries=1 --spider http://localhost:3100/ready || exit 1" ]
      interval: 10s
      timeout: 5s
      retries: 5
    networks: &loki-dns
      loki:
        aliases:
          - loki
    logging:
      driver: loki
      options:
        loki-url: "http://xxx.xx.xxx:3100/loki/api/v1/push"
  write:
    image: xxxxxx/xxx/se-loki-write:3.3.2
    deploy:
      mode: replicated
      replicas: 3
    command: "-config.file=/etc/loki/config.yaml -target=write"
    ports:
      - 3104-3106:3100
      - 7946
      - 9095
    volumes:
    healthcheck:
      interval: 10s
      timeout: 5s
      retries: 5
    networks:
      <<: *loki-dns
    logging:
      driver: loki
      options:
        loki-url: "http://xxxx.xx.xxx:3100/loki/api/v1/push"
 grafana:
    image: xxxxx/xxxxx/se-loki-grafana:latest
    environment:
      - GF_PATHS_PROVISIONING=/etc/grafana/provisioning
      - GF_AUTH_ANONYMOUS_ENABLED=true
      - GF_AUTH_ANONYMOUS_ORG_ROLE=Admin
    depends_on:
      - gateway
    entrypoint:
      - sh
      - -euc
        mkdir -p /etc/grafana/provisioning/datasources
        cat <<EOF > /etc/grafana/provisioning/datasources/ds.yaml
        apiVersion: 1
        datasources:
          - name: Loki
            type: loki
            access: proxy
            url: http://gateway:3100
            jsonData:
              httpHeaderName1: "X-Scope-OrgID"
              manageAlerts: false
            secureJsonData:
              httpHeaderValue1: "tenant1"
        EOF
        /run.sh
    ports:
      - "3000:3000"
    healthcheck:
      test: [ "CMD-SHELL", "wget --no-verbose --tries=1 --spider http://localhost:3000/api/health || exit 1" ]
      interval: 10s
      timeout: 5s
      retries: 5
    networks:
      - loki
    logging:
      driver: loki
      options:
        loki-url: "xxxxx.xx.xxx:3100/loki/api/v1/push"
  backend:
    image: xxxx.xxxxx.xx/se-loki-backend:3.3.2
    volumes:
      - ./rules/rules_puppet.yaml:/etc/loki/rules/fake/rules_puppet.yaml
    ports:
      - "3100"
      - "7946"
    command: "-config.file=/etc/loki/config.yaml -target=backend -legacy-read-mode=false"
    depends_on:
      - gateway
    networks:
      - loki
    logging:
      driver: loki
      options:
  gateway:
    image: xxx.xx.xxx/se-loki-nginx:latest
    depends_on:
      - read
      - write
    entrypoint:
      - sh
      - -euc
        cat <<EOF > /etc/nginx/nginx.conf
        user  nginx;
        worker_processes  5;  ## Default: 1
        events {
          worker_connections   1000;
        http {
          resolver 127.0.0.11;
          server {
            listen             3100;
            location = / {
              return 200 'OK';
              #auth_basic off;
            location = /api/prom/push {
              proxy_pass       http://write:3100\$$request_uri;
            location = /api/prom/tail {
              proxy_pass       http://read:3100\$$request_uri;
              proxy_set_header Upgrade \$$http_upgrade;
              proxy_set_header Connection "upgrade";
            location ~ /api/prom/.* {
            location = /loki/api/v1/push {
            location = /loki/api/v1/tail {
            location ~ /loki/api/.* {
        EOF
        /docker-entrypoint.sh nginx -g "daemon off;"
    ports:
      - "3100:3100"
    healthcheck:
      test: ["CMD", "service", "nginx", "status"]
      interval: 10s
      timeout: 5s
      retries: 5
    networks:
      - loki
    logging:
      driver: loki
      options:
        loki-url: "http://xxx.xx.xxx3100/loki/api/v1/push"
I can’t find the documentation at this moment, but ruler essentially has two modes. You either use filesystem and set enable_api to false, or you set enable_api to true and you’d have to use S3 storage. You cannot enable ruler API with filesystem storage.
Thanks for the reply.
What I found is that for those that are not using Helm charts and just deploying via docker-compose and using read/write/backend architecture, the example provided here, does not contain the changes from this commit in the nginx gateway config. Specifically, the proxy for the /loki/api/v1/rules endpoint should be set for proper prefix matching.
            location = /loki/api/v1/rules {
              proxy_pass       http://backend:3100\$$request_uri;
            location ^~ /loki/api/v1/rules {
It might be nice to have a basic, out-of-the-box working example for docker-compose that includes a working rules/alerts config.
