Hello, ![]()
Absolute beginner here.
I want to have my logs and metrics from a Heroku Dyno into Grafana Cloud with the minimum maintenance work possible -
From my understanding I would need a Promtail instance running in order to scrap the logs AND a Prometheus Agent to scrap the metrics.
Am I right or I’m missing something? Is this the easiest way of doing it?
If this is the way, then it means that I would need 4 instances just to scrap my two Heroku Dynos (Production and Staging), two for each?
Thanks for your time!
