AWS-managed Grafana v10.4.1
- What are you trying to achieve?
I’m following this: Forecasted alerts with Grafana and InfluxDB. I’d like actual and forecast values properly labelled in the timeseries visualization.
- How are you trying to achieve it?
I have the same query: SELECT ... AS actual, ... AS forecast .... In Grafana’s Explore tab, the alias of $col worked as expected.
I’m setting the alias to $col and the display name to ${__field.labels.host}: ${__field.labels.path} (${__field.name}).
- What happened?
The legend shows names like my-host-1: /tmp (Value) (twice, once for actual and once for forecast).
- What did you expect to (hoped would) happen?
I hoped to see names like my-host-1: /tmp (actual) and my-host-1: /tmp (forecast).
- Can you copy/paste the configuration(s) that you are having problems with?
I think I did above. If you’d like more detail, please let me know.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No.
- Did you follow any online instructions? If so, what is the URL?
- General query: Forecasted alerts with Grafana and InfluxDB
- Alias patterns: InfluxDB query Editor | Grafana documentation
- Display name: Configure standard options | Grafana documentation
Many thanks!
