Hi there, I’m looking for some help to achieve a project. I hope my issue will be easy enough to understand and please forgive my english issues.
I’m using Grafana v8.5.2
I’m working on a project and I just want to be able to display images coming from a Python script.
Currently my Python script is starting a camera and fetching some frames from it.
Then i’m encoding these frames into Base64 and trying to send them to the Grafana Live measurement ( /api/push/live/custom_stream_id with Telegraf )
I succeed in sending values like maths functions, but I couldnt send any strings with this method.
My idea was trying to make a dashboard with images displaying like Ed Welch did in his Nissan Leaf work : Nissan Leaf -> Cloud all the things - GrafanaCONline | Grafana Labs
In this work he talked about Grafana LOKI to store Base64 images, but i didnt find any documentation about that ( probably because i’m very new in this ).
- How are you trying to achieve it?
I tried with this piece of code:
Please note that i tried with this code ( maths one ) as well and it worked very fine :
With this one, I was able to create a live dashboard as it is mentionned in Grafana Stream Metrics documentation. ( Without websockets )
- What happened?
With the First piece of code i’m getting an Internal Server Error ( 500 ) and Logs from grafana said : Error parsing metrics.
I’m sure that it come from the “metrics format” but didnt manage to find how to solve it.
I wanted to have the base64 encoded images in a Grafana table to display it.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
Error Parsing metrics in Systemctl status grafana-server
- Did you follow any online instructions? If so, what is the URL?
I took some ideas from this topic : https://community.grafana.com/t/how-to-connect-streaming-data-source-to-websocket/54927
I would be glad to have any ideas or documentations to read about Loki storing Images.
Thanks for Helping if you can do it !
