Adding image to the dashboard
    Grafana v11 Enterprise
    Adding an image from local disk directory which is the most recently added image in that directory (needs to update in realtime), plus I will be working with a PC with no internet access.
    Watch directory using telegraf, convert the image that has been newly added to base64, send it to InfluxDB, query the data with Grafana and display on dashboard
  • What happened?
    I do not even know if it is possible…if anyone has done it before it would be really helpful.
I’ll check that for sure. Thank you
