Just started with grafana. Trying to convert our kibana dashboards to grafana.
Stuck with one issue hope someone can point me in the right direction.
I got a table with log messages. I need to inspect a large text field with trace information from this table.
The textfield is to big to display directly in the table.
In Kibana it currently a expand collapse when you click on the table row.
Anybody got a solution for this? A popup or expand collapse possible from table? Or do I need to create a new dashboard where you can inspect a single log message?
Kind Regards,
Tim
