Discrete panel not drawing upon loading dashboard
I have got the discrete panel working nicely with my MS SQL datasource but when I load the dashboard the colours don’t draw unless I fiddle with the color mappings (go to add a colour, everything starts working again and then delete).
How can I make sure the panel draws correctly upon startup?
Thanks
Brett
Just found on the panel Github page that there is a known bug with the new version 5.4.0 and this panel. Looks like the developer has already fixed it. I’m going to download the panel direct from their github page.
Hope this helps someone else…
Thanks,
Brett
