Discord 0auth2 constantly trying to create an account that is already created
[auth.generic_oauth]
enabled = true
name = Discord
allow_sign_up = true
client_id =
client_secret =
scopes = identify guilds email
;empty_scopes = false
auth_url = Discord
token_url = https://discord.com/api/oauth2/token
api_url = https://discord.com/api/users/@me
teams_url = https://discord.com/api/users/@me/guilds
team_ids_attribute_path = [*].id
team_ids = ; GUILD-ID for the discord server
use_pkce = true ;CHATGPT MODIFICATION
login_attribute_path = email ;CHATGPT MODIFICATION
id_token_attribute_name = id ;CHATGPT MODIFICATION
name_attribute_path = username ;CHATGPT MODIFICATION
email_attribute_path = email ;CHATGPT MODIFICATION
    I am trying to allow only members of my discord server (and later people with specific roles on my discord server) to be able to log into my grafana instance.
    By utilizing Discord 0auth2
  • What happened?
    For new users it creates and logs in perfectly well, but if the user logs out and attempts to log back in using the Discord 0auth method again, it returns an error “Login failed User sync failed
    If the user exists it just logs in
    As above
  • Did you receive any errors in the Grafana UI or in related logs? UI returns an error “Login failed User sync failed” at the login screen
    There are no instructions on the internet on how to do this, the fact i got it generating the account is nothing short of a miracle.
I guess your workaround will be:
I guess proper solution is that you need to configure identity provider/Grafana to create/detect proper unique user id, which can be used to detect if user exists or not.
You didn’t provide enough debug input, so both are only qualified guesses.
