Disable image zoom in table
    Grafana 11.0 by Docker
    I want to disable image zoom on hover
  • What happened?
    After upgrading to Grafana v11, the images in the table began to zoom on hover.
This is inappropriate in my use case. The images are large, they overlap the entire table and are not fully displayed. How do I disable that feature?
I reproduced the problem on play.grafana.org . Below are screenshots of how it looks with large images
and problem
Thank you
you could try the dynamic text plugin instead?
Thank you. I understand that I can make a table from a Dynamic Text Panel. But then I will have to do a lot of functions manually - sorting, adding columns, etc. I’d like to use the standard table panel without that nasty zoom.
if it worked fine before uograde it might be a regression bug. i would create a github bug issue
In my table, cell Type Image, the images actually do not zoom when hovering over them, instead, the Title text appears.
But I WANT them to enlarge on hover, so how can I achieve that?
