Hi.
Is it possible to remove the “Alerting” section from the left side menu?
Would it be possible for instance to remove it by editing the grafana.ini configuration file?
Hi.
@ginoliuz You can disable Alerting or Unified Alerting in the config.ini or environment variables following documentation
When Alerting is disabled, you won’t see it in the menu.
Hi @mikhailvolkov
Thank you for your reply.
Do you mean the grafana.ini file in etc/grafana directory?
@ginoliuz It depends on your installation, for Linux packages, it’s in the /etc/grafana
@mikhailvolkov thank you for your reply.
Yes, it’s a Linux installation. To be precise, I used the docker image and the file should be /etc/grafana/grafana.ini
I suppose.
I can see from the link you shared that there are two “alerting” options in the documentation ( [unified_alerting] and [alerting] ).
I tried to disable the first one by modifying the aforementioned file but the container crashes as soon as I attempt to start it.
Is it the second one?
Or should I disable both of them at the same time?
