Hello, i just want to disable the Grafana alerting, and not alertmanager.
Is it possible ?
welcome to the
forum, @dan
have you tried using this toggle in the prometheus datasource configuration?
you can also diasble the entire alerting platform using Grafana’s config settings:
I will want to disable only the internal alerts on Grafana, not the AlertManager integration on Alerts, so i can’t use the configuration for disable the entire alerting platform.
Any idea for disable only the Grafana core alert ?
Similar question here.
How to disallow Grafana users to create Grafana-managed alerting rules while allowing Loki/Mimir managed rules?
Tried the alerting quota in Grafana INI but it didn’t work.
