Enabling Grafana 8 alerting
Grafana: 8.3.4
Amazon Linux 2.
Also have prometheus installed.
My problem is I follow the directions here: https://grafana.com/docs/grafana/latest/alerting/unified-alerting/opt-in/
But can not enable Grafana 8 alerting. I used the rpm to install so I do not have a custom.ini. However in my grafana.ini that it’s pointed at has.
Alerting
[alerting]
;enabled = false
and under
[unified_alerting]
;enabled = true
So according to the docs I should be enabled. But when i go under alerts I see a message of “Try out Grafana 8 alerting!.. You are using legacy Grafana alerting…”
so what gives how do i get the new alerting to work?
remove the semicolon that starts the line. Restart Grafana, and see if Unified Alerting is working
[unified_alerting]
enabled = true
ugh. so am i a moron? I didn’t realize that a “;” would comment out the line as the entire file is littered with semi-colons. in fact every line single line in the config file that is not a “#” comment has a “;” in front of it…
but taking those semi-colons out worked, thx.
