is it possible to disable the predefined admin account?
You can change the default admin username and password using the following configuration parameters. Otherwise you can log in with the admin account and change password or remove it, be sure to mark another user as Grafana Admin before you remove it (Grafana admin is not the same as organisation admin role).
Marcus
As per my understanding, we can remove admin but after removing we can still login with admin name that will be having read only permission. This is the scenarios I saw in grafana5 beta.
And as Marcus mentioned, be sure to mark another user as Grafana Admin before you remove it.
-Himanshu
