"admin" user disabled
Hello Everyone,
I am unable to login into Grafana as “admin” user. I see below error in the grafana.log file
t=2021-01-07T14:54:12+0300 lvl=warn msg="User is disabled" logger=http.server user=admin
t=2021-01-07T14:54:12+0300 lvl=eror msg="Invalid username or password" logger=context userId=0 orgId=0 uname= error="User is disabled" remote_addr=10.2.180.25
t=2021-01-07T14:54:12+0300 lvl=info msg="Request Completed" logger=context userId=0 orgId=0 uname= method=POST path=/login status=401 remote_addr=10.2.180.25 time_ms=1 size=42 referer=http://10.2.122.50:9205/login
t=2021-01-07T14:54:24+0300 lvl=info msg="New state change" logger=alerting.resultHandler ruleId=23 newState=pending prev state=ok
t=2021-01-07T14:54:26+0300 lvl=info msg="Successful Login" logger=http.server User=rcesh@sps.com
We haven’t disabled the user yet we are getting this issue. Could some please suggest how to fix this issue.
Settings in grafana.ini file:
[security]
# disable creation of admin user on first start of grafana
;disable_initial_admin_creation = false
# default admin user, created on startup
admin_user = admin
# default admin password, can be changed before first start of grafana,  or in profile settings
admin_password = admin
# used for signing
;secret_key = SW2YcwTIb9zpOOhoPsMm
# disable gravatar profile images
;disable_gravatar = false
# data source proxy whitelist (ip_or_domain:port separated by spaces)
;data_source_proxy_whitelist =
Thank you in advance.
-Ravi
please set
cookie_samesite = none
and cookie secure to true
Hello Melrose,
I updated grafana.ini file as you suggested. But I am still facing the same issue.
[security]
admin_user = admin
# used for signing
# disable protection against brute force login attempts
;disable_brute_force_login_protection = false
# set to true if you host Grafana behind HTTPS. default is false.
cookie_secure = true
# set cookie SameSite attribute. defaults to `lax`. can be set to "lax", "strict", "none" and "disabled"
# set to true if you want to allow browsers to render Grafana in a <frame>, <iframe>, <embed> or <object>. default is false.
;allow_embedding = false
# Set to true if you want to enable http strict transport security (HSTS) response header.
# This is only sent when HTTPS is enabled in this configuration.
# HSTS tells browsers that the site should only be accessed using HTTPS.
# The default version will change to true in the next minor release, 6.3.
;strict_transport_security = false
# Sets how long a browser should cache HSTS. Only applied if strict_transport_security is enabled.
;strict_transport_security_max_age_seconds = 86400
# Set to true if to enable HSTS preloading option. Only applied if strict_transport_security is enabled.
;strict_transport_security_preload = false
Any other suggestions which I can try?
-Ravi
What happens if you try to Reset the admin password?
Also, are you sure you want to be posting your secret key on a public forum?
Hello Diana,
I did reset admin password through grafana-cli but with no success.
The public keys posted are not the real one :slight_smile:
-Ravi
Someone must have disabled your user. Have to use sqlite3 open open database and change user table, or mysql/postgres client if you use any of those as main db.
Hi Torkel,
Thank you for the suggestion. I have followed Sqlite documents to update ‘user’ table.
@Everyone,
For those who are facing similar issue or want to access Grafana default database (Sqlite), following are the steps:
To access database:
root@grafanahost> sqlite3 /var/lib/grafana/grafana.db
To list Tables:
sqlite> .tables
To view schema of a table:
sqlite> .schema <tablename>
Eg: sqlite> .schema user
To view table data:
sqlite> SELECT id, name, is_disabled FROM user;
To update a column:
sqlite> UPDATE <tablename> SET <columnName>=<value> WHERE <condition>;
Eg: sqlite> UPDATE user SET is_disabled=0 WHERE id=1;
To exit:
sqlite> .exit
@ravichandran just wanted to take the time to thank you for this solution! I had already gone through uninstalling grafana and reinstalling it to no avail. Thanks for posting this!
