I am a windows user & developer, I have been checking your tutorials on panel plug in your web pages and it starts by using a “ *grafana-toolkit“ tool that I can not find, would you be so kind to point me in the right direction please?
If you have NodeJS installed you can run grafana-toolkit with npx:
npx @grafana/toolkit plugin:create my-plugin
If that doesn’t work for you, you can find grafana-toolkit on NPM: https://www.npmjs.com/package/@grafana/toolkit
Hello @jaimermzb
You may give a try to WSL,
It is easy to install and will give you a look and feel of Ubuntu command line.
V.
