Decimal to hex then to ascii, on a time series
Hello everyone,
I am running Grafana v10.4.1 in a container on Kubernetes
i am using the OpenNMS Grafana performance data source.
The data is stored as a decimal value and sent to Grafana as a decimal. I want to graph the data on a time series graph. after a bunch of data conversions, I found the data had to be converted from a Decimal to hex and then to Ascii to get a human-readable value.
example of the end result will be ‘10.0%’, ‘25.8%’, etc
yes the percent symbol is included after the conversion
any help would be appreciated.
There is no way for me to change the data source on the NMS side
Thank you in advance
why can’t you just specify units and decimals? why do you need hex/ascii?
Hello, the data comes in as Decimal like this ‘52974935093285’ and i need to convert that value to hex and then the hex result to Ascii. like below
decimal to hex
represent this as hex is not a problem and could be done just by changing unit to Hexadecimal:
but as for further conversion I don’t think that would be possible to do in Grafana at the moment
may be you can think of introducing some middleware between your data source and Grafana, i.e. Node-RED
ya thats what i figured but just thought someone else had todo the same. i did find it might be possible with apache echarts but i have looked into it yet. Thanks for assistance on this
yes it can be done with Business Chart leveraging js/ts within it. please post the data as text not an image.
and you want this as a timeseries? but how can that be when you have datetime and some ascii?
The data source is OpenNMS Plugin for Grafana plugin for Grafana | Grafana Labs
yes as a time series and how is why I’m here
this is what is returned in json format. could i not just run the values from fglinkMonitorPacketLoss into js with apache echarts to get the desired results?
  "state": "Done",
  "series": [
      "name": "",
      "length": 12,
      "fields": [
          "name": "Time",
          "type": "time",
          "config": {},
          "values": [
            1722017700000,
            1722018000000,
            1722018300000,
            1722018600000,
            1722018900000,
            1722019200000,
            1722019500000,
            1722019800000,
            1722020100000,
            1722020400000,
            1722020700000,
            1722021000000
          "state": null
          "name": "fgLinkMonitorPacketLoss",
          "type": "number",
          "config": {},
          "values": [
            3544385881675673600,
            null,
            null,
            null
          "state": {
            "calcs": {
              "sum": 31899472935081062000,
              "max": 3544385881675673600,
              "min": 3544385881675673600,
              "logmin": 3544385881675673600,
              "mean": 3544385881675673600,
              "last": null,
              "first": 3544385881675673600,
              "lastNotNull": 3544385881675673600,
              "firstNotNull": 3544385881675673600,
              "count": 9,
              "nonNullCount": 9,
              "allIsNull": false,
              "allIsZero": false,
              "range": 0,
              "diff": 0,
              "delta": 0,
              "step": 0,
              "diffperc": 0,
              "previousDeltaUp": true
yes you can parse that json (fgLinkMonitorPacketLoss) and do whatever you want in Business Chart (artist formerly known as apache echarts) But you will also need the Time
first pass. then you can manage the data within the code section to do your conversion. plenty of examples here
https://echarts.volkovlabs.io/d/pL5iH7FVk/home?orgId=1&refresh=5s
and docu here
