Date format issue (solved)
Hi, new to Grafana so pls, bear with me.
I want to create a simple graph from queries A & B:
SELECT temp, saved AS 'time' FROM dht ORDER BY saved ASC (or SELECT temp, UNIX_TIMESTAMP(saved) AS 'time' FROM dht ORDER BY saved ASC)
SELECT humidity, saved AS 'time' FROM dht ORDER BY saved ASC (or SELECT humidity, UNIX_TIMESTAMP(saved) AS 'time' FROM dht ORDER BY saved ASC)
I don’t get any errors nor I get data in the graph grid.
Do I have a datetime format issue?
Here’s a basic output from mysql:
|“21.75”|“2020-08-11 19:03:40”|
|“22.88”|“2020-08-11 19:13:40”|
|“23.44”|“2020-08-11 19:23:40”|
|“23.72”|“2020-08-11 19:33:40”|
|“23.86”|“2020-08-11 19:43:40”|
Never mind. I was storing temp and humidity in string format. Converting them to decimals, solved my problem.
