You should get be getting a useful error message instead of “bad request data” though. I’ll look into that!
Something like ‘Mute timing saved’? If so, yes, I got this message.
But I am wondering right now, will I get alerts between 23:59 and 00:00 UTC, this is between 5:59 am and 6:00 am in my local time, already a new day a in one minute will these alerts get trigger or what?
I just checked the docs, it looks like you should be able to write 24:00 instead of 23:59 to fix the issue of having 1 minute unmuted.
I thought it won’t work, but I tried and it is working!
Waiting for new day to check the alerts, thanks a lot!
Hello, George.
Right now I am testing grafana v10.1.5 and there is a problem with custom labels. In Notification Policy when I add these labels for matching alerts, there is nothing, 0 instances. So my question is there a bag or am I doing something wrong. I’m doint this because I have alerts for 24h and 20m, I have a mute timing for 24h alerts and I need to specify mute timing for 24h alerts, for other alerts as in default Notification Policy. Because of that alerts gets keep triggering at 6am.
I didn’t find any solution for this problem, so I decided to ask it from you.
Sorry and Thank you!
