grafana:8.2.5 , inside docker container ubuntu 5.15.0 -
grafana is running on docker container, so my datasource configuration should be in yml file while loading the container rather adding it on UI manually -
Inside the/etc/grafana/provisioning/datasources, I am trying to add datasource yaml file for azure monitor, But already I have promotheus yml (prometheus.yml) file.
I am not sure, is it technically possible to have more than one .yml file or I need to have both the configurations in one yml file
What happened?
After I added yml file for azure monitor datasource, the docker container failed to start -
My expectation is we need to add this configuration through yml file instead of manually doing from UI. -
File path:/etc/grafana/provisioning/datasources
grafana.yml file
apiVersion: 1
datasources:
- name: Grafana
type: grafana-azure-data-explorer-datasource
isDefault: true
access: proxy
editable: true
jsonData:
azureAuthType: clientsecret
cloudName: azuremonitor # See table below
tenantId: {{ vault_AZ_TENANT_ID }}
clientId: {{ vault_AZ_CLIENT_ID }}
secureJsonData:
clientSecret: {{ vault_AZ_SECRET }}
prometheus yml file
apiVersion: 1
datasources:
- name: Prometheus
type: prometheus
url: http://prometheus:9090
isDefault: true
access: proxy
editable: true
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
grafana | Failed to start grafana. error: Datasource provisioning error: datasource.yaml config is invalid. Only one datasource per organization can be marked as default
grafana | Datasource provisioning error: datasource.yaml config is invalid. Only one datasource per organization can be marked as default
- Did you follow any online instructions? If so, what is the URL?
No I didnt yet follow any
