Datasource API with Private data source connect
    • Grafana Cloud, latest
    • create/update a datasource over the http api, including the Private data source connect network
    • no starting point
  • What happened?
    • nothing
    • adding the Private data source connect network programmatically
  "datasource": {
    "id": 1,
    "orgId": 1,
    "name": "test_datasource",
    "type": "graphite",
    "typeLogoUrl": "",
    "access": "proxy",
    "url": "http://mydatasource.com",
    "password": "",
    "user": "",
    "database": "",
    "basicAuth": false,
    "basicAuthUser": "",
    "basicAuthPassword": "",
    "withCredentials": false,
    "isDefault": false,
    "jsonData": {},
    "secureJsonFields": {},
    "version": 1,
    "readOnly": false
  "id": 1,
  "message": "Datasource added",
    • no
    • did not find anything
Use browser console to find out what UI is using:
@jangaraj Thanks a lot for the tip!
The relevant fields are
"enableSecureSocksProxy": True,
"secureSocksProxyUsername": "<your-pdc-id>",
They must be added to jsonData
