Database and table variables working
I have a query in my panel in my dashboard where I get the database and table from variables. I got it working on one of my dashboards, but for some reason I can’t get it working on another.
SELECT
  "Date",
  "EID Not Found" AS "Product without RFID tag"
FROM ${databasePERC}.${tablePERC}
WHERE "Filter" = 'day'
ORDER BY time DESC
LIMIT 30
error:
ValidationException: The query syntax is invalid at line 4:34
The query variables are query all databases and tables from my AWS Timestream through my datasource. I show the valiables (with label) on my dashboard so I can swap between datasources to change what I see in my panels.
The variable names match up, so I know that’s not the issue.
Somebody know anything?
Try to add Text panel so as to visualize the value of:
Would your query work if you replace variables in query with their values copied from the text panel?
Or try
${databasePERC:doublequote}.${tablePERC:doublequote}
May be your database name or table name contain dashes or other ‘bad’ symbols
yea got it working like this now:
FROM "${databasePERC}"."${tablePERC}"
weird, because the first dashboard I got variables working I didn’t use quotes, but it worked anyway.
May be values of the variables at that dashboard didn’t contain dashes etc., but on this they do have
