Business Variable
*** What Grafana version and what operating system are you using?**
I use Grafana v9.5.19
*** What are you trying to achieve?**
apply and link the data to use the variable to have dynamic dashboard
    by linking the variables with query and have dynamic filters
  • What happened?
the variables is correct but when i link it to the query , it cues tow things
1- didn’t work or show any data
2- error, by not read or recognize the element in the database
    the filters work and the variables linked correctly
select orign_EN ,count (ItemCode) as ‘Total shipments’ FROM DBMaster.V2 WHERE orign_EN = ‘$test’
GROUP BY orign_EN order by count (ItemCode) desc
Status: 500. Message: db query error: mssql: Incorrect syntax near ‘Khamis’.
    No
welcome to forum
please show us the query that uses the filters. or click on Query Inspector and show us a screen shot of the query inspector
Even the variables are linked, this issue is still there
this the query that i use :
select orign_EN ,count (ItemCode) as ‘Total shipments’ FROM DBMasterUn_V2 WHERE orign_EN = ‘$test’
and for the variables:
SELECT DISTINCT orign_EN FROM DBMasterUn_V2 WHERE orign_EN IS NOT NULL ORDER BY orign_EN
now click the Query Inspector button and see what the actual query looks like
select orign_EN ,count (ItemCode) as ‘Total shipments’ FROM DBMasterUn_V2 WHERE orign_EN = ‘’ Khamis Mushayt post office’,’ mosadeah Dcs’,’ Sawyer’,’ Tabarjal’,‘Abanat’,‘Abdullah Fouad’,‘Abha Central Post’,‘Abhor’,‘ABO SUOD’,‘Abqaiq’,‘Abu Arish’,‘Adhem’,‘Afeef’,‘AFIF Dcs’,‘Ahad Al Masarhah’,'Ahsa Central Post ',‘AJAWEED’,‘AJF 27’,‘Al Aflaj’,‘Al Aidabi’,‘Al Ais’,‘Al Akrbiyah’,‘Al Aqeeq’,‘Al Arda’,‘Al Awali’,‘Al Awamiya’,‘Al Badaya’,‘Al Badi’‘ah’,‘Al Baghdadiya’,‘Al Bark’,‘Al Batha’‘a’,‘Al Bawadi’,‘Al bjadih’,‘Al Bukayriyah’,‘Al Dae’‘r (Bani Malik)’,‘Al Dalam’,‘Al Dawadmi’,‘Al Derayih’,‘Al Derb (Al Qyias)’,‘Al Dulayimiya’,‘Al Faisaliah’,‘Al Fawarah’,‘Al Ghazala’,‘Al Hafayer’,‘Al Haiet’,‘Al Ha’‘ir’,'Al Hajra ',‘Al Haram’,‘Al Hareeq’,‘Al Hasa Farma Operation Center’,‘Al Hawiyah’,‘Al Henakia’,‘Al Itisalat District’,‘Al Jabriya’,‘Al Jame’‘a’,‘Al Jmom’,‘Al Jouma’‘a’,‘AL KHAFJI Dcs’,‘Al Khalidiya’,‘Al Kharj’,‘Al Kharmh’,‘Al Khata’,‘Al Khobra’,‘Al Laith’,‘Al Madhleef’,‘Al Majarda’,‘Al Majma’‘a’,‘Al Makhwah’,‘Al Malaz’,‘Al Maznab’,‘Al Mendaq’,‘Al Mesa’‘ediya’,‘Al Misfalah’,‘Al Moueh’,‘Al Mountaza’,‘Al Mubarraz’,‘Al Muhamadiya’,‘Al Muzahmiah’,‘Al Naeiria post office’,‘Al Namas’,‘Al Nassej’,‘Al Nassem’,‘Al Nbhanah’,‘Al Nour Mountain’,‘Al Nuzha’,‘Al Omran’,‘Al Ouayina and Al Jubaila’,‘Al Ouoon’,‘Al Qadisiyah’,‘Al Qahma’,‘Al Qaisumah’,‘Al Qassab’,‘Al Qeblatain’,‘Al Qrra’,'Al Quayeyah ',‘Al Qunfudah’,‘Al Quoz’,‘al Qura’,‘Al Qurayyat’,‘Al Rakah’,‘Al Rass’,‘Al Rawabi’,‘Al Rawda’,‘Al Rayan’,‘Al Rhine’,‘Al Rouna’,‘Al Rweidh’,‘Al Safa’,‘Al Sahn Bani Sa’‘ad’,‘Al Sail Al Kebeer’,‘Al Salama’,‘Al Salhia’,‘AL SAMER office’,‘Al Sefarat’,‘Al Seleel’,‘Al Sena’‘iah’,‘Al Shamasiya’,‘Al Shemli’,‘Al Shifa’,‘Al Shoua’‘ra’,‘Al Shqeq’,‘Al Shsha’,‘Al Sinayia Al Thania’,‘Al Tahliya’,‘Al Tarf’,‘Al Ula’,‘Al Umrah’,‘Al Wajha’,'Al Zohour District ',‘Al Zulfi’,‘ALBSATEEN’,‘Aldayery’,‘Aljroshi Mall Boxes’,‘AlKhobar Dcs’,‘Almlqa Area’,‘Alnoor District Office-Dammam’,‘AL-Olaya Dark Store’,‘Alwadi’,‘Alyasmeen Dark Store’,‘AlYasmin Office’,‘Amlaj’ ‘’
do you see the issue?
what do you see could be the issue with this sql query
Oh, but is the space the issue?
even when I change the query, and the error, it shows no data at all
should be WHERE orign_EN in (‘etc’)
i try it , the same issue :frowning:
ahow us the query inspector result
I fix it, the issue was in the format, I use the basic query in the variable:
FROM DBMasterUn_V2
and in the SQL query
SELECT orign_EN, COUNT(ItemCode) AS 'Total shipments'
FROM DBMasterUn_V2
WHERE orign_EN IN ($test)
GROUP BY orign_EN
ORDER BY COUNT(ItemCode) DESC;
The proviso in where condition , i was trying by
WHERE orign_EN = '$test' -- and this the cuses of the issue
It supposed to be
Thank you for your effort and for your support
