v8.5.2 (90701be19)
I would like to have my entire dashboard be filtered with some custom filter I create based on some query variables.
I have several query variables at the top of the dashboard that the user can multiselect, and in all of the panels, there is the same where-clause that is based on these variables.
Every time I change/add a variable, I need to go to all of the panels and update the query.
I’d like a way to create a where-clause that will interpolate the variables and be inserted to my bigquery query. -
I tried using custom/constant/text box but it seems like variable chaining is only supported in query variables.
Also ad hoc filters are no use as they don’t support bigquery -
Couldn’t find any. Everywhere seems to lead to no solution
Hi atlanteh, which syntax and database are you currently using ? ![]()
@grafunkel thanks for your message!
I’m using bigquery with the sql syntax (not the builder).
Hi atlanteh, i am not really into sql and grafana variables, but if i remember right you can achieve these variables if you just query over your data columns and SELECT every DISTINCT entity if i am right.
This should help with creating a grafana variable.
The other subject regarding querying your variables:
i ve found some old post regarding this. Someone has linked their variables inside their sql syntax like that:
Hope it helps
Grafu
I am using variables, the problem is that I have a dashboard with about 7 variables, that all panels use exactly the same, so every time I need to tweak the query I need to go to all panels and update the, where I prefer to have a simple variable that would hold the “where” clause with all other variables. the problem is that variable interpolation only works for query variables, not custom/text variable
I’m also looking to do something similar and went through the same process as @atlanteh : trying to create a constant/custom/textbox variable to reuse in all my panels.
