Is it possible to directly visualize data from load tests on Grafana Cloud (k6)?
I have a pipeline for each load test, and I want to create a data visualization in Datadog (just results or real-time data). This is possible when the test runs locally, but not in the cloud - as I know.
Init [ 0% ] Loading test script…
Init [ 0% ] Building the archive…
Init [ 0% ] Validating script options
Init [ 0% ] Uploading archive Test run URLs:
/bilka-basket/PREPROD/VUS-100.js: https://.grafana.net/a/k6-app/runs/3478582
execution: cloud
script: /root/github-action-runner-work/GrafanaCloud-k6/GrafanaCloud-k6/bilka-basket/PREPROD/VUS-100.js
output: https://.grafana.net/a/k6-app/runs/3478582
scenarios: (100.00%) 1 scenario, 15 max VUs, 6m5s max duration (incl. graceful stop):
* ramping_load: Up to 1.00 iterations/s for 5m50s over 5 stages (maxVUs: 15, startTime: 5s, gracefulStop: 10s)
Run [ 0% ] Initializing the cloud test
Unable to get pull request number for the commit, skipping comment creation
Run [ 0% ] Waiting…
Run [ 0% ] Waiting…
Run [ 1% ] 0m13.0s/6m5s
Run [ 43% ] 2m46.0s/6m5s
Run [ 100% ] 6m04.0s/6m5s
Run [ 100% ] 6m5s
Run [ 100% ] 6m5s
test status: Finished
Run [ 100% ] Finished time=“2024-11-08T11:11:16Z” level=error msg=“Thresholds have been crossed” Test failed with code: 99 and signal: null Some tests failed
