Hello - I have a couple questions about the supported data sources:
- Assuming I can implement any of your supported sources, do you have any recommendation for which will work best on resource-restricted hardware? (think a Raspberry Pi)
- If the answer to #1 is either Postgres or MySQL, can you tell me what features are not available from these sources that are available from the other more specific time-series data stores?
