Hi at all, i’m on grafana Grafana v10.4.1 with the data manipulation plugin and i want to add an ambient variable in the data source section inside the initial request/update request .
Can it be done? @mikhailvolkov
if it is inserted manually, it doesn’t save
thanks
@nicolomenelle Data Manipulation supports all backend data source in the current release with custom payload. In the upcoming version 4.0.0 we added Query Editor support for Data Sources.
Please check out our documentation and YouTube videos on how to work with data sources.
yes, i use it ${ambient} but inside this data source section there’s no way to put it inside
